2015 BMW S 1000 XR
2015 BMW S 1000 XR
Mensagem por amandio » 04 nov 2014 09:32
The new BMW S 1000 XR
The BMW S 1000 XR – all good things come in fours.
Following on from the S 1000 RR and HP4 superbikes as well as the S 1000 R roadster, BMW Motorrad is now unveiling the fourth member in the BMW Motorrad line-up of high-power motorcycles with straight-four-cylinder engines and a distinctly sporty bias. Building on the tantalising and unique mix of innovative technology, performance and safety already inherent to the existing models in this series, BMW Motorrad has taken the next step by bringing out the S 1000 XR, which offers this repertoire of core characteristics in a brand-new blend dubbed “adventure sport”. This encompasses dynamic touring qualities, sporty performance and high levels of comfort as well as outstanding everyday usability. In short, the new S 1000 XR serves up its own individual mix of sporting and touring flair at the same time as injecting a generous dose of emotion.
Straight-four-cylinder engine for punchy adventure sport performance.
The straight-four-cylinder engine on the new BMW S 1000 XR is basically derived from the S 1000 R roadster. It has an output of 118 kW (160 hp) at 11,000 rpm and generates maximum torque of 112 Nm (83 lb-ft) at 9,250 rpm. This power unit produces torque in abundance, making it ideal for providing the punchy response at low and medium revs that riders seek when powering along country roads or carrying a passenger. The straight-four-cylinder unit combines tremendous pulling power and exhilarating acceleration with a high peak output, while offering the rider a usable rev range that spans over 10,000 rpm. This makes it just as adept at highly pleasurable touring as it is at sporty rides down winding country roads or holiday trips complete with passenger and luggage.
Two riding modes and ASC as standard as well as the option of Pro riding modes including Dynamic Traction Control (DTC) and ABS Pro.
To enable the riding characteristics to be adapted to the prevailing road conditions as effectively as possible, the new S 1000 XR already comes with the “Rain” and “Road” riding modes as standard. The standard-fit Automatic Stability Control (ASC) ensures a high standard of riding safety by optimising traction. The new S 1000 XR can be equipped ex-works with the Pro riding modes option, which includes the additional riding modes “Dynamic” and “Dynamic Pro” along with Dynamic Traction Control (DTC) and ABS Pro.
Innovative chassis with a new frame and Dynamic ESA (Electronic Suspension Adjustment) as an option.
The chassis of the new S 1000 XR adventure sport bike is every bit as impressive as the ferocious power delivery of the four-in-line engine. Based on this model series’ existing design, it employs an aluminium-alloy perimeter frame in which the engine forms part of the load-bearing structure. Wheel suspension at the front and rear is handled by an adjustable upside-down fork and a double-sided swing arm with adjustable central spring strut respectively. The chassis geometry has been completely redefined in order to cater to the specific requirements of the XR. When fitted with the optional electronically controlled suspension system BMW Motorrad Dynamic ESA (Electronic Suspension Adjustment), meanwhile, the new S 1000 XR takes riding safety, performance and comfort to even greater heights, while also promising adventure sport at its very finest.
ABS Pro available ex-works as part of the Pro riding modes option for even greater safety when braking in a banked position.
Whereas the standard ABS systems from BMW Motorrad to date have ensured an excellent standard of safety when braking while moving in a straight line, the optionally available ABS Pro feature now goes a step further to make braking while cornering safer as well by enabling ABS-assisted braking in a banked position. In such situations, ABS Pro prevents the wheels from locking up even when the brakes are applied sharply. This reduces abrupt changes in steering force, especially in response to panic braking, and thereby limits any undesirable righting of the bike. ABS Pro offers riders the benefit of increased braking and riding stability combined with optimum stopping power, even in corners.
The new S 1000 XR – style and function for both sport and adventuring.
The new BMW S 1000 XR fuses the characters and strengths of the BMW Motorrad GS, Touring and Sport models on a visual level as well to create a new breed of motorcycle tagged “adventure sport”. This is clearly mirrored in every design element and combines with the flawless ergonomics, ingenious wind and weather protection as well as the 20 – 30 mm increase in spring travel and greater ground clearance to make an impressive statement. Whether it’s mountain passes, a tour of the countryside, motorway riding or even rough sections of road – the new S 1000 XR handles it all with aplomb.
Highlights of the new BMW S 1000 XR:
- Straight-four-cylinder engine with a displacement of 999 cc. Output 118 kW (160 hp) at 11,000 rpm, maximum torque of 112 Nm (83 lb-ft) at 9,250 rpm.
- Dynamic, innovative design with sculptural surface styling.
- BMW Motorrad ABS as standard (semi-integral, disengageable).
- ABS Pro for even greater safety when braking in a banked position (as part of the Pro riding modes optional extra).
- Automatic Stability Control (ASC) as standard for accelerating safely even in low-grip conditions.
- Dynamic Traction Control (DTC) with banking sensor for supreme performance and active riding safety when accelerating (as part of the Pro riding modes optional extra).
- Two riding modes that can be selected by the rider at the push of a button as standard (“Rain” and “Road”).
- Two additional riding modes available, “Dynamic” and “Dynamic Pro” (as part of the Pro riding modes optional extra).
- Spring elements with long spring travel for excellent agility and high damping reserves.
- Electronically controlled suspension system, Dynamic ESA (Electronic Suspension Adjustment) for optimum adaptation to the prevailing conditions as an optional extra.
- Light-footed handling and raised seating position.
- Multifunctional instrument cluster with a wealth of features.
- Extensive equipment and bespoke range of accessories made to BMW Motorrad’s customary high standards.
Fonte: BWM Press Group
Imagem Imagem
FRAME WORK
Imagem Imagem
ABS PRO
Color Schemes
Imagem Imagem
Imagem Imagem
CONCEPT
Imagem Imagem
Imagem Imagem
Imagem Imagem
Imagem Imagem
Imagem Imagem
Imagem Imagem
Imagem Imagem
Re: 2015 BMW S 1000 XR
Mensagem por JoseMorgado » 04 nov 2014 11:20
Grande BOMBA!!
Talvez, demasiado parecida com a Multistrada.....
Mensagem por amandio » 04 nov 2014 11:31
Concordo em parte...
JoseMorgado Escreveu:Talvez, demasiado parecida com a Multistrada.....
Mas se reparares é a frente da RR com um bom trabalho ao nível do "corpo"
E sim é uma séria concorrente para a Multistrada em vários termos.
A BMW está a tentar, com os modelos base, fazer alterações para chegar aos vários nichos de mercado.
Parece-me um boa aposta mas vamos ver os resultados. :mrgreen:
Mas para mim, apesar de ser (Sport) Trail, não é a minha onda... anda mais que o meu anjo da guarda :lol:
Mensagem por amandio » 04 nov 2014 13:27
Entrevista com o responsável pelo desenvolvimento dos modelos S1000 sobre a XR
http://youtu.be/5JInmKNwuj0
Mensagem por JoseMorgado » 04 nov 2014 14:24
amandio Escreveu:para mim, apesar de ser (Sport) Trail, não é a minha onda...
Também não é a minha "onda", mas que é apelativa, É!!
Mensagem por amandio » 05 nov 2014 09:02
Mensagem por JoseMorgado » 23 fev 2015 21:43
Nas minhas voltas com R1200R deste fim de semana, encontrei estas S1000XR's na garagem da Penha Longa. O segurança só me deixou espreitar ao longe!!
A BMW Motorrad está lá instalada, até 31 de Março, com os Dealers do Mundo inteiro.
Também lá estavam outros modelos, mas estas é que estavam mais bem guardadas!
Muitas já foram vistas na zona de Sintra/Estoril/Cascais
j luis
Mensagem por j luis » 23 fev 2015 23:44
Tantas :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Mensagem por amandio » 24 fev 2015 09:59
Será que o Natal chegou mais cedo este ano????? :twisted:
Mensagem por JoseMorgado » 24 fev 2015 10:25
Para alguns colaboradores e convidados da BMW Motorrad, o Natal é todos os dias!!
