2011 BMW R 1200 R And R 1200 R Classic
Mensagem por amandio » 04 nov 2010 14:43
BMW Motorrad Press Release:
The second model to be displayed by BMW Motorrad at EICMA Show is R1200 R, in both standard and Classic versions. Both combine a modern sporty and accentuated classical motorcycle design, once again with considerably greater quality and driving dynamics for even more riding fun.
The new R 1200 R is powered by a 1170 cc engine that delivers 110 HP at 7750 rpm and a peak torque of 119 NM at 6000 rpm. The new bike will be offered in three exterior colors: mat metallic smoky gray, metallic light gray, or metallic red apple.
Both the R 1200 R and the R 1200 R Classic can be fitted optionally with electronic suspension adjustment ESA. This serves to vary the spring base and the suspension’s pressure and rebound stages at the rear wheel, and the suspension’s rebound stage at the front wheel – a system that has established itself as the solution for optimized road handling and comfort.
With the new BMW R 1200 R and R 1200 R Classic, BMW Motorrad is continuing its long tradition of roadster building and presents the revised successor models to the successful R 1200 R. Both combine a modern sporty and accentuated classical motorcycle design, once again with considerably greater quality and driving dynamics for even more riding fun.
Generating perceptibly higher torques, the new boxer engine provides an extra boost to temperament. Whereas the boxer in the predecessor model had already provided superior propulsion under all conditions, the new BMW R 1200 R models can deliver more on top. Derived from the BMW HP2 Sport, their new boxer with 1170 cc and DOHC valve gear corresponds to the engines already installed in the BMW R 1200 GS and BMW R 1200 RT.
Thanks to ultra modern technology in conjunction with two different design concepts, the new BMW roadsters are setting discrete emphasises in the segment to a degree greater than before.
Whereas the basic version of the BMW R 1200 R emphasises the sporty all round character with new cast light alloy wheels, the R 1200 R Classic presents wire spoke wheels for a deliberate touch of refined nostalgia.
This demarcation between the two new roadster models is also continued in the colour of the paintwork and other equipment details. For instance, the R 1200 R Classic pays homage to the classic roadsters with metallic sapphire black paintwork in conjunction with a centre stripe in plain alpine white extending over the tank and front wheel cover.
The basic version of the R 1200 R is available in mat metallic smoky grey, metallic light grey, or metallic red apple: three colour schemes representing a dynamic, elegant, and modern interpretation of the roadster.
These three colour variants when combined with wheels and drivetrain in Nürburg silver highlight the sporty, dynamic side of the roadster. The R 1200 R Classic, on the other hand, deliberately goes for a refined contrast and emphasises components like the Telelever, drivetrain, cylinder head covers, frame, and fork with silver. Their classical, refined quality also finds expression in the completely chromium-plated exhaust system and the mirrors with a chromium look, whereas the basic version provides a sporty touch in the form of a rear silencer in brushed stainless steel and black rearview mirrors.
Despite the differences in visual appeal presented by the R 1200 R and R 1200 R Classic, they are nevertheless united in their technology.
For instance, maximised rigidity and strength is provided by the tried and tested, two part main/rear frame, which has a weight-saving structure of steel tubing is designed with the engine as a load-bearing element for maximum stiffness and rigidity. The front suspension of the new BMW R 1200 R trusts in the BMW Telelever in conjunction with a new fork structure. Its high quality, technical grace and the enlarged diameter of the standpipe (from 35 to 41 mm) contribute decisively to shaping the face of the new R 1200 R. The rear suspension takes the form of the tried and tested single arm with BMW Paralever.
Both the R 1200 R and the R 1200 R Classic can be fitted optionally with electronic suspension adjustment ESA. This serves to vary the spring base and the suspension’s pressure and rebound stages at the rear wheel, and the suspension’s rebound stage at the front wheel – a system that has established itself as the solution for optimised road handling and comfort.
The maximum safety standard is ensured by the established and proven brake system, which can be fitted in the factory with the optional BMW Motorrad integral ABS (in the partially integral version) and automatic stability control ASC.
In its role as a traditional system provider, BMW Motorrad has also developed for the new R 1200 R and R 1200 R Classic extensive ranges of optional equipment and tailored optional accessories for further individualisation.
The following presents an overview of the essential features of the new BMW R 1200 R and BMW R 1200 R Classic:
Clear differentiation between the R 1200 R and R 1200 R Classic in the form of characteristic colour concepts and equipment features.
New dynamic drive, now with double overhead camshafts in each cylinder.
Maximum torque raised to 119 Nm at 6000 rpm, and rated power raised to 81 kW (110 hp) at 7750 rpm.
Maximum engine speed now raised from 8000 to 8500 rpm for an even wider utilisable speed range.
Perceptible improvements to torque values for even greater roadster pleasure on country roads.
Spontaneous response with optimised controllability and clearly improved load-alteration effects.
Cylinder-head covers now with two instead of the previous four mounting bolts and a new, dynamic styling.
Shorter, sportier rear silencer in brushed (R 1200 R) or chromium-plated (R 1200 R Classic) stainless steel.
Electronically controlled exhaust flap for a superior powerful sound.
Cast light alloy wheels (R 1200 R).
Wire spoke wheels with light alloy flat collar rims (R 1200 R Classic).
ESA (electronic suspension adjustment) (optional factory fit).
BMW Motorrad integral ABS in the partially integral version (optional factory fit).
Automatic stability control ASC (optional factory fit).
Redesigned cockpit with two round analogue instruments.
New hydraulic reservoirs with a smoked glass look.
Extensive range of optional equipment and tailored accessories at the familiarly high BMW standards.
worksounds
Re: 2011 BMW R 1200 R And R 1200 R Classic
Mensagem por worksounds » 04 nov 2010 15:51
Muito bonita :).
Mas não é uma GS. :mrgreen:
Ex BMW GS1100 RED
Ex BMW K1100 RS
Mensagem por jpgoncalves » 04 nov 2010 22:45
A R1200R continua lindissíma, era uma das motas que não me importaria nada de ter. 8)
JoaoCarlos
Mensagem por JoaoCarlos » 05 nov 2010 00:00
R1200R será provavelmente a continuação da moto mais bem equilibrada da BMW
gostos à parte este modelo enche sempre as medidas de qualquer pessoa
Cumprimentos e excelentes curvas
Joao Carlos
R1200GS
KDX200
sócio 458
http://www.fcporto.pt
Jpmatos
Mensagem por Jpmatos » 05 nov 2010 09:16
Gostei! :)
João Paulo Teixeira de Matos
Sócio nº 494
BMW R1200 GSA Rallye (2018) "The Screaming Eagle II"
BMW R Nine T (2014) "Ninette"
KTM 690 Enduro R (2012)
"The journey is the reward" Steve Jobs
joaopedro
Mensagem por joaopedro » 05 nov 2010 10:41
Sempre gostei muito do conceito "naked", apesar dos prós e contras que todos conhecemos. :wink:
Esta está, de facto, muito bonita. :D
João Pedro Caldeira
R1200GSA´14
Sócio nº 273
Mensagem por josecunha » 05 nov 2010 12:10
joaopedro Escreveu:Sempre gostei muito do conceito "naked", apesar dos prós e contras que todos conhecemos. :wink:
Eu também, principalmente se for a Catarina Zeta Jones 8)
cmart
Mensagem por cmart » 05 nov 2010 12:17
josecunha Escreveu:
Já não gostas da Soraia ?
Carlos Martins
R1200 GSA "Aventurinha"
CBR 600F Sport "Princesa"
Schuberth C3
Sócio nº398
http://www.bmw.cmartfoto.com/
http://www.dive.cmartfoto.com/
http://www.cmartfoto.com/
Mensagem por josecunha » 05 nov 2010 12:22
É muito grande e está cheia de celulite, um nojo :lol:
Última edição por josecunha em 05 nov 2010 13:41, editado 1 vez no total.
cmart
Mensagem por cmart » 05 nov 2010 12:25
Mas tu é que estás sempre a dizer que devemos preferir o produto Nacional... :D :D
Carlos Martins
Schuberth C3
Sócio nº398
